Hi guys, my car has this poor acceleration issue for 3 years now and none of the mechanics so far could find the problem, but lots of things were done with no luck.
I own a 1.2 mk2 punto 8V which should have a top speed of 155km/h and an acceleration 0-100km/h in 14.5 seconds, am I right? (I googled factory specs)
Well mine has a top speed of 149km/h and astonishing lightning fast acceleration 0-100 in only 36.7 seconds!!! (did multiple tests this was the best)
The following are the things done so far, not fixing the acceleration issue ... yet
- changed complete exaust manifold, also removed catalytic converter (thought it was clogged) gained about 5% power and a hell of noise out of the exaust
- put KN air filter gained maybe 5% power
- engine rebuild because 1 cylinder had bad compression (changed piston rings, valves, flying bearings, valve rubber rings and valve guides) gained about 10% power
- adjusting valve clearence because there was a ticking noise on every rev. Now this is strange because after adjustment I lost around 20-30% of power, despite ticking noise was gone.
Diagnostics show no faults at all, sensors and sensor readings seem fine, O2 sensors working, input manifold vacuum is around 18 idle, 20-22 when driving, new sparkplugs, cleaned fuel injectors a few times had no influence on engine power. Idle is steady but sometimes there is a random "bump" the flow from the exaust is sometimes uneven, fuel economy is awful and there is like unburned fuel smell from the exaust although ECU shows no missfires. I did reset the ECU after valve adjustment but it was the same. Fuel pressure is 3.5 bars and does not drop, very sudden push on the gas pedal makes the engine almost completely stop.
Any ideas on this? Im open for questions and suggestions. I will take the car to check those valve clearences again to a different workshop but before I spend more money on that, maybe there are some good ideas.
Thanks in advance!
Thanks in advance!
