Hi folks,
I'm currently preparing to install a Meta M752A/M15 mykro alarm system into my 2000 Punto Mk2 1.2 8v ELX, which already came with factory installed remote central locking.
Unfortunately, the manual isn't very detailed, and right now I'm having trouble finding a proper grommet/hole to get the alarm wiring loom from the engine bay into the cabin.
There is a big grommet behind the battery, but that one is already in use by the main wiring loom coming from the fuse box.
Here are some pictures of my situation:
Here you can see a close-up of the grommets that I've found so far, which are located behind the battery. Only problem is, that it's completely full already. I basically need another one of those big grommets.
Finally, as you can see in the photo below, there are no grommets on the left side of the engine bay..
Is there another grommet hidden somewhere under or near the firewall?
Any help will be highly appreciated.
Cheers,
Martijn
Cheers,
Martijn
