mgrenonville
- Nov 2, 2012
- 6
- 1
Hi everybody !
First, please excuse my english, it's not my first langage !
My punto was ok, but, three month ago, sometimes, i had some misfires, and the engine warning light on for 200km. I thought it was the plugs, so, i changed it. As it was not a permanent problem, I thought it was ok, and my punto did not misfire for a while.
Another day, (i was going on holiday), my punto started to misfire a lot (with the orange warning light), and, it did not fire without problem since that day !
I search the internet, but i was not able to say if it was a misfire of one plug, or two. So i bought a ELM327 on dx.com, and had a P0351 diagnostic code. So, coil or ECU problem.
I follow the guide "Punto coil-ECU checks". I build a light probe with two LEDs and resistor.
When starting the engine, i saw that i have the +12V on one pin of the coil connector.
On the second, when i connect it to the negative probe, and the positive to the +12V it start flickering fast enought, i guess. So i change the coil. BUT it did not solve the problem Should i change the ECU ?
I try to use the old coil on the firing coil, it works. DO you have any idea ?
Thanks a lot for reading me !
