lol, starting to run out of ideas on this 1.
I found a damaged Hill Hold sensor, by the airbag module.. well I say damaged the plastic casing was damaged.
Changed it.. and thought that will be whats causing the hill hold failure error if dampness is getting in there or has got in it at some point.. didnt look too clever inside. because normally its a sealed unit with a rubber type sealant around the top.
so after changing it, thought great that hopefully has cured it.
then tonight it flashed up hill hold failure, esp failure again.
battery isnt even 2 years old yet so can probably rule out that.
going to try brake pedal switch next, but it seems to be working fine.. lights arent sticking on and they come on and go off fine.
tried to see if theres any way of adjusting it? but couldnt see any visible way of adjusting it. So I guess new switch replacement is next thing to try.
