tony barnes
- Mar 5, 2008
- 12
- 3
The other half's '03 Punto has started playing silly buggers all of a sudden
1. The electric fan was making some weird squeaky noises, now has stopped working entirely (thank god it's cold out at the minute!). I've checked fuses and they seem fine - I'm guessing dead motor? Easiest way to check just to test current across it? Any particular way?
2. Airbag light is on. Again fuses all appear fine, unless there are some hidden ones..? lol
3. Engine can be fluttery first thing in the morning, feels like it's not firing on all cylinders, or is having a fueling issue. The battery didn't seem to like the cold a while back, and a couple of times it was nearly dead in the morning (clock reset, etc, but able to start). Not sure where to start on this - stick in a new battery? Swap over HT leads? Check the coil pack? Check the injector? Check the fuel pump? All of the above!?!?
4. Oh, and finally, the power steering is occasionally deciding to do nothing, usually at same time as dodgy power from point 3. Engine off/on sorts this immediately...
It feels to me like there is something wrong with the electrics, as all of these problems could have electrical basis, and they all came along at the same time give or take a few weeks. Is this something that someone has experienced? Are the looms prone to failure in some way? I'm used to old minis, so fix it with a wrench and hammer, so thought I'd ask around in case these were common known issues
Cheers for any help!
