Had the codes read on my JTD Punto today as it randomly doesn't unimmobilise itself. When I put the key in and turn the ignition sometimes the key light doesn't go out. The codes stored are: P0601: ECU Defect (EEPROM) U1600: Electronic Key If I want to start the car (once the ignition is on and the key symbole hasnt gone out) I have to turn the ignition off and pop the key out slightly, turn the radio on (It comes up with 'CHECK') then when the radio comes on it will start as normal. Any ideas?
