| | Thread Tools | Search this Thread |
Posts: 25 Thanks: 0 Trader Rating: 0 | Hello, I posted a few weeks ago regarding how to do the Timing and today i managed with a friend to look at this and we noted all the timing marks lined up correctly, i also clean the sensor but this has had no effect. I will try to explain what happens and hopefully someone can help me out. When i first start the car from cold its very sluggish and some times it backfires (only and small popping sound not a large bang). Once i get it started i allow it to heat up and try to pull away but to pull away without any kangaroo effects (holdingback/ jumping forward) i have to give it plenty revs. Also i have noticed that its more of a problem at low revs and if for example i was going a steady 40mph (i dont notice and probs here) but wanted to push towards 50mph as soon as i hit the accelerator i get some slight kangeroo effects. Does anyone have any ideas? Cheers
| | Quote
| | #2 |
| | Re: Punto acceleration problems the backfire is unburnt furl soo to me sounds like something on the ignition side of things. not firing especially when damp and cold. you have probaly checked all ready but what about the plugs ? leads and coil pack ?
__________________ 2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm |
| | Quote
| | #3 | ||
Posts: 25 Thanks: 0 Trader Rating: 0 | Re: Punto acceleration problems Well we checked the plugs and all were a sandy colour which i guess is ok, but how can i check the leads and where is the coil pack?
| | Quote
| | #4 |
Posts: 76,421 Thanks: 1255 Trader Rating: 10 | Re: Punto acceleration problems coil pack is the other end of lead to the plugs, did you check plugs for a spark? if they dont spark and if you fit new and the new plugs still dont spark its proubly coil pack or maybe leads
__________________ Respect is something that should be automatically given to people. It is trust that is earned not respect |
| | Quote
| | #5 |
| | Re: Punto acceleration problems well sandy color is correct color for plugs. the ht leads can be visualy checked make sure there are no cracks or splits along the length of the casing. the coil packs are what the ht leads plug into (other end to the spark plug) i dont know how you can check these. someone else on here may no. what car have you got by the way?
__________________ 2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm Last edited by thefishdude; 23-11-2004 at 22:46. |
| | Quote
| | #6 | ||
Posts: 25 Thanks: 0 Trader Rating: 0 | Re: Punto acceleration problems Punto 1.1 sx mate "Hello dave" Can i assume as the Spark plugs have a sandy colour that all the plugs are ok and that the leads are ok and the coil is ok as they all the this one job?
| | Quote
| | #7 |
| | Re: Punto acceleration problems i would say no you cant sandy plugs is good sign for the plugs but dont mean rest is ok.
| | Quote
| | #8 |
Posts: 76,421 Thanks: 1255 Trader Rating: 10 | Re: Punto acceleration problems no you gotta check they spark
| | Quote
| | #9 | ||
Posts: 25 Thanks: 0 Trader Rating: 0 | Re: Punto acceleration problems How can i do that?
| | Quote
| | #10 |
Posts: 76,421 Thanks: 1255 Trader Rating: 10 | Re: Punto acceleration problems take plug out, fit it back in lead, lay it on top of engine, get frient to turn engine over look at it if its sparks nice blue spark in the gap its ok, dont touch it though while he is turning it over it will hurt.
| | Quote
| | #11 | ||
Posts: 25 Thanks: 0 Trader Rating: 0 | Re: Punto acceleration problems Cheers mate, will this prove the coil, leads and plugs work? Any other ideas as going to scrapyard tomoz with uncle and have another look...
| | Quote
| | #12 |
Posts: 76,421 Thanks: 1255 Trader Rating: 10 | Re: Punto acceleration problems if they all spark all is ok, but if 1 or 2 of them dont swop them for the ones that do if they still not spark its coil pack
| | Quote
| | #13 | ||
| | Quote
| | #14 |
Posts: 76,421 Thanks: 1255 Trader Rating: 10 | Re: Punto acceleration problems you gonna nick this stuff? coil packs would be handy, dont fit second hand leads or plugs they are cheep enough anyway, and a carb would be no good to you because puntos dont have them
| | Quote
| | #15 | ||
Posts: 25 Thanks: 0 Trader Rating: 0 | Re: Punto acceleration problems no pay as little as pos mate.
| | Quote
| | Dee | Punto (Mk2/2b) | 18 | 18-10-2007 11:10 |
| Punto Head Problems | edwardsj | Lets Talk FIAT | 3 | 21-09-2004 23:19 |
| | belgrade_punto | Punto (Mk1) | 9 | 08-02-2004 02:16 |
| Audio problems in Punto ELX | Quenchmaster | I.C.E | 6 | 18-01-2004 05:10 |
| | DR_EVIL | Punto (Mk1) | 8 | 12-07-2003 05:07 |
