Technical mk2b sporting timing belt.
daryn
Punto Sporting 1.4 '04 :)
Glasgow
:) hey ,
i read in the owners manual that its not due until 72,000 miles,
mine has 65k on the clock at the moment, should i get it done before the 72k or wait til then ?
cheers.
Has fiat even told anyone (except themselves). Im the original owner and purchaser of my 05 sporting and they haven't told me jack s***.
fiat dont make belts
"Introducing Dayco's New Mileage Warranty Program"
It just doesn’t make sense to spend hours tearing down a car’s engine to change a timing belt and then to discount the importance of inspecting the tensioners and pulleys that are incorporated into the timing belt system. Worn tensioners and/or idler pulleys often contribute to the excessive wear or failure of the belt. If this is the case, and these components are not replaced…the belt life of a newly replaced timing belt will be drastically reduced.
Dayco aftermarket timing belts and Dayco aftermarket timing belt tensioners and idler pulleys meet critical OE standards for fit, form and function. In fact, we’re so confident in the quality of our products and the credibility of our application engineering that we back this claim with our exclusive Dayco Mileage Warranty Program. This program ensures that, if during the same repair service, the timing belt along with worn timing belt tensioners and/or idler pulleys are replaced with a Dayco Timing Belt and Dayco Timing Belt Component Kit Tensioners and/or Idler Pulleys…Dayco will warrant both the belt and tensioner and/or idler pulleys for the life of the automotive manufacturer’s original recommended replacement interval. If no OEM timing belt replacement interval is recommended, then the typical trade practice of replacing the timing belt and components at 60,000 miles will apply. The warranty will become effective if the timing belt or any of components fail prior to the designated replacement interval. An invoice carrying the date of replacement, odometer reading at time of replacement and odometer reading at the time of failure will be required along with the failed timing belt and components.
edit dayco now have advance belts with a special coating
Hang on did I say they did?. All I said was "FIAT" published in their customer vehicle documentation to get it changed at 72,000 miles. It is then "FIATS" reponsibility to then tell said customers of this change to 3years or 36,000 miles.
Who the hell is going to know who manufacturers the belts or even know where to go online to check what you've just posted? :bang:.
Thats the point im trying to make. Personally if mine snapped at 3yrs and 36,000miles i'd be going after fiat to fix the damage as i'd be following their documentation and service booklet.
A similar thing happened with the Alfa Twinsparks (although they really were snapping JUST after 36k) and Alfa were rembursing customers who had maintained their service history.
lol they can snapp too though, and common to stretch causing timing inaccuracies. Oh and are less efficient :(.
The likelyhood of them snapping is a lot lower tho also they don't perish and are not subject to problems with oil contamination making them go soft. As long as they are maintained could last a very long time indeed although mines a got a bit of noise that wouldn't be there with a belt at idle.
Ford state 100,000miles or 10 years in documentation but they will not honour it because its a recommendation.
Alfa done this (and it was often a part contribution) to retain their dwindling customer base.
Yeah, but it's not in Fiat dealer garage, it's in a backyard garage...a garage that has a stamp on the bill and on service book would charge you abbout 40-50 EUR
I wouldnt be suprised if Fiat dealer here would charge you 100 EUR as in GB, and part (belt) could be 30-50 EUR cause its original (?)
oh dear this thread has scared me a bit, i thought it was 5 years or 72k miles!
My car is now 5 years old but only done 30k miles, im going to get the belt changed this xmas, just hope nothing happens before i get it done :(
