Fred in a shed
- Sep 13, 2008
- 7
- 1
My 2003 1.2 8V Punto is now running on 3 cylinders. Problem started soon (5 miles or so) after refilling a very nearly empty fuel tank - misfiring and the engine warning light first flashing then staying on) so my initial thoughts were dirty fuel but, with all the rain and flooding on the roads that day, I didn't want to add 2 + 2 and get 5 so I borrowed a scanner to see what the fault codes were.
Got the following: P0302 misfire on No. 2, P0202 injector No. 2 circuit malfunction, P0445 evaporative emission control system - purge control valve circuit, and a couple of unidentified ones U1600 & U1601. After poking around a bit, checking that HT leads etc were secure, I ran another scan and got all of the above again plus a new one: P0352 ignition coil primary/secondary circuit.
I started by looking at the spark plugs - all looked the right colour (no unburnt fuel in No. 2). Then I tried swapping the coils around but the problem stayed at No. 2 cylinder (another scan - same fault codes) so I thought that the ignition system is probably OK and started on the fuel system. Thought I was getting close when I removed the plug from No. 2 injector when engine was running and it made no difference at all - same lumpy idle. Doing the same with any of others caused the engine to stall.
Then I tested the resistance of all 4 injectors - all were about 15 ohms so seemed OK. Then, with ignition on, I measured voltage across terminals of each injector plug - 1,3, & 4 were just under 2V, No. 2 was only 0.6V. I traced +ve wire from No. 2 injector back to connector at ECU (goes to the plug on the driver's side), cut wire just before plug and checked voltage again - no change from 0.6V so wiring harness is probably OK up to plug. Lots of WD40 plus refitting/wiggling of the plug didn't change things. Couldn't test if connection in plug itself was OK because the probes on my meter leads are too big.
Now thinking dark thoughts about it being the ECU or possibly the multipin connector - both bad news.
Please can anybody offer some wise advice on what to do next, before I have to start throwing money (that I don't have) at the problem?
