Hi All
My Son has just got a Mk 2 X reg Punto.
Has any one changed the cam belt on a Mk 2 Punto 1242cc 8v engine
I have done this on older fords, but note that the Haynes manual recommend
You get the tension check by fiat, does any one know a way to check the tension On this engine, and is it correct that if the belt breaks no damage is done to the 8v engine. also would you also change the Water pump at the same time.
Regards Roger
Regards Roger
