matty seasider puntopower! Parked in the garage Joined May 25, 2003 Messages 1,239 Points 340 Location northwest Apr 4, 2007 #1 i need to take my passenger side drive shaft off as loads of cv grease is flying out the cv boot, and im wondering what size socket i need to remove the hub nut? cheers people!
Punto.Power Patron member Joined Oct 4, 2006 Messages 1,854 Points 338 Location Scotland Apr 4, 2007 #2 Im sure the front hub size is 36mm and rear is 32mm..
D DanGil Member Joined Jan 23, 2006 Messages 875 Points 136 Apr 5, 2007 #3 yep 36mm, you'll also need your spare wheel and a big f*ckoff bar.
OP OP matty seasider puntopower! Parked in the garage Joined May 25, 2003 Messages 1,239 Points 340 Location northwest Apr 5, 2007 #4 spare wheel? how does that help get the hubnut off!?!
D DanGil Member Joined Jan 23, 2006 Messages 875 Points 136 Apr 6, 2007 #5 It has the centre cut out, so you can put it on and lower it to the ground. That way you have the weight of the car on it as its bloody tight .
