I took my Fiat Panda 2004 (1.2) for the annual test today and they told me that the servo light is coming up and is showing signs that it may have a faulty or not work at all. Now I know for sure it works, but I've been having this problem that it turns on and off randomly, sometimes working for days and other days it's constantly on. Having such bad luck it turned on during the test, only a 20m drive from the parking lot to the testing area. It all started while I was trying to find an issue with the car burning too much fuel, turns out it was an O2 sensor. After fixing that, now the servo is having this issue. Now the car has an electrical servo and I've read online that if the sensor is faulty the whole steering system has to be changed. Is it worth fixing? Is there a way to check what's causing the issue? I can't bother going to a mechanic because of the costs and the value of the car. Besides I've fixed everything else without a mechanic.
The steering automatically locks, sometimes steers fast to the left and is very hard to steer in any direction. Before it turns on it randomly shakes a bit and steers very little to the left. If I turn the car off and let it rest for a while the light goes away. No faulty codes are given on the computer. I've had the MAP sensor, the O2 sensor and the throttle body changed recently, all because of ignorant mechanics. Having issues trusting anyone atm and school starts in two weeks and the car is only eligible for drive for another month.
