- Sep 14, 2009
- 19,492
- 3,294
My 500 axle (under the 169 Panda) has now done a winter of salt and crud. All is well however.
The axle is from a 2015 Fiat 500. The condition was of course excellent but I reasoned a coat of Hammerite would not go amiss. So its was treated to 2 coats of brushed smooth silver. Before painting, I rounded off any sharp edges (where the metal was cut) with an angle grinder & flap wheel. Sharp edges thin the paint causing it to flake away.
After the winter there are a few rust stains creeping from under the metal edges. It's really no big deal and easily sorted with an anti corrosion spray. But annoying all the same.
If anyone wants to do this job or indeed clean up a 169 axle, I would suggest it is well worth the cost of grit blasting and zinc metal spray. You can paint over the top if you like.
Yes, it's belt & braces and I'm probably OCD about a bit of rust stain, but my car is a 2007 and this is the only area where it has shown it's age.
The cost would be about £50 to grit blast, then you have to prime and paint it costing considerable time and maybe >£30 in paint. £100 to grit blast and zinc spray the whole axle looks like a bargain.
