- Jun 3, 2016
- 149
- 56
Hi all,
I wrote recently regarding the message flashing up on the dash when the engine failed to start within a couple of seconds.
just to add that since ive put on a new middle and back section exhaust which were blowing badly!! over a week ago I've not had this message again. I thought that maybe the engine being 'damp' first thing may have been a possible cause but past 5 days it's been tipping it down and even flooded but she fires up first time! Weird!
Also the battery was mentioned but on further checking the battery is a recommended one and is quite new and holding its charge so that was ruled out.
SO basically im not sure why my panda had the funnies starting but im a lot happier now!
Mind you its only been over a week but i'll keep you all posted if the problem returns then its off to the fiat garage to be sorted
