Hi Folks
Long time since I posted anything. About to add a 3rd Panda to the stable.
We're looking for a 1.2 ECO or a 1.3 Multijet.
Just seen a 2009 1.2 ECO.
It drove OK, but I was concerned about the exhaust, rear suspension, a minor leak under the bonnet, no cam-belt change.
Is this just normal for the age of car?
How long has the exhaust got left in it?
Looks like the springs & cups need a good wire brushing and waxoil.
I spotted a coolant hose(?) with some cracks.
I hope that the attached pictures are clear enough:
What do you reckon?
Cheers C.T.
P.S. Got the VIN number but can't get the VIN recognised in the on-line eper that I found referenced by the forum
- Engine bay is generally nice and clean - but some signs of some sort of fluid leak behind the dipstick.
- One of the rubber tubes (near the top O/S engine mount) shows signs of cracks.
- Rusty rear springs and cups. Though I suspect this is normal for a 2009 car.
- Sump is rustier than I expected - but I suspect will last a good few years.
- I can see the oil filter has been changed - oil on the end of the dipstick was clean.
- I can't tell if the timing belt looks like the original. There is no mention of a timing belt change in the service notes.
- Exhaust back box - is de-laminating.
- The link pipe seems to be a solid tube of rust.
What do you reckon?
Cheers C.T.
