Hello guys, I'm new and confused! I have a 58 plate petrol Panda 4 x 4 which I took to the local garage today, and the mechanic said that the joint (I think he said it was a joint!) on the prop shaft that makes it a 4x 4 is worn out, and replacements are not available to buy anymore. The last person here who needed one eventually tracked one down in Spain apparently!
He said that the only real option is to make it into a 2 wheel drive. It's done 27,500 miles, I've had it from new, and don't go off-road in it. I have it, because I live on a mountainous island in the middle of nowhere, off the west coast of Scotland.
Now, bearing in mind that I'm a 65 year old female with little mechanical knowledge, can anyone confirm that this is right? I do know the mechanic well, but apart from one of two threads on here from some time ago which do mention the prop shaft, can't see this particular problem mentioned anywhere else online.
Any information/advice will be very gratefully received. Thank you.
