After having this problem with the sqweaky peddle etc, and peddle stuck to the floor, reading many replies and posts from people. I have come to the following conclusion. people all try to help saying "master cylinder" - "low fluid" - "water in fluid" etc etc here is my 2 penny worth ( yorkshire saying lol ) go for the slave cylinder first. i pulled the boot off ( oh and while we are on about the boot and the funny little part of a tie wrap thats there - will explain in a min ) spray it with wd40 or similar will work for a few days at least. then get a new / second hand one. i have spray arm etc, and all over the slave cylinder seemed to cure for a few days. even bought a second hand one for £15 off fleabay, not had to fit it yet but carry it in car just in case as is only 10 min job to do it. So how can i be sure its the slave ? I saw a add on ebay for a slave cylinder and says fits panda & ford KA. looked up ford KA and the cylinder is the same, even same numbers on it. ok so same part so what ? look on the ford KA forums. loads of posts about clutch sticking to the floor etc.
only common thing is the same slave cylinder . same one - same fault. ok wont cure 100% of faults but is a good start.
now the little bit of white tie wrap under the black one. this is just to hold the plunger in while you fit it, it is then cut to release it for use.
have a look at picture ( thats if i have uploaded it properly )
