ahumbletramp
great. im going to attempt to fit these myself, as I usually get a garage to do it for me, so I want to make sure I have everything so I dont waste a day for nothing.
Had the last damper changed, and the top mounts yesterday. No more knocking from the back, and a huge difference in cornering speed and control. Haven't had the bill from the mechanic yet, but parts are around £100 so far.
Eventually I would like to go lower, and will probably change to Koni Str.t when that happens.
I am looking at buying a Panda 100 (not 100% sure yet after reading about the suspension problems, other options are Clio 182 Cup) and have test driven a couple so far.
The second car I drove has 52k miles and felt very crashy on uneven roads.
Suspension is one of my main interest/hobbies and I want a car that has good ride quality, doesn't crash/bottom out on potholes and handles well.
Reading this post it seems the good quality options are:
- Koni STR T
- Koni yellows (do they come with lowering springs and if so by how much do they lower the car? I don't really want to lower the car, if the suspension travel is already so short, the suspension needs travel to work properly and it seems there is not enough of it already from factory)
- Bilsteins (which model?)
- H&R although I don't can't justify paying £1k if the car costs a little less than £3k, I may as well look at other cars then.
Also, do all of the above require custom made bolts as mentioned here?
https://www.fiatforum.com/500/338796-koni-fsd-rear-shock-rattle-shock-4.html
http://www.abarthforum.co.uk/500-abarth/fsd-koni-knocking-the-solution/
Thanks for your help.
Also aren't the custom made bolts required for the Panda as well or does the issue with the knocking only occur in 500s?
I can't post links unfortunately but if you search for "Koni FSD rear shock rattle" you will find the thread I am referring to.
