Hi all, I’ve got a 2004 1.2 8v with 87,000 miles. Have just noticed that the front shock absorbers have started to leak again (standard Fiat ones! :bang after just 50,000 miles. I want to do a proper job so I have a few questions to ask.
Just found some Koni STR.T's on eBay, I’m just wondering if they are any good?
In addition, I know the springs are original, so it worthwhile replacing them as well?
Thirdly, the strut top mounts have only done 45,000 miles so should I just leave them or replace them?
I will be replacing the drop links out of good measure and will probably keep the wishbones (only done 20K since they were changed).
The rear end seems quite bouncy over undulating surfaces (springs and shocks are totally original) so should I also consider replacing them too?
Give me your thoughts on what I should do, cheers, Adam .
