General Cup holder inserts
p111dom
The cup holder liners have perished on the car going brittle and broke into pieces when I put the vacuum cleaner near it. Anyone know where I can get some replacements or is it a dealer part?
is that the little gridded discs at the bottom that covers the bolt hole..??,
or a "sleeve" ..??, i've only got the discs on my '04 active,
Charlie
Yes that's the ones I'm on about. They simply cover the bolts.
Hi and welcome to the forum (y)
One of my inserts broke up in exactly the same way - while vacuuming the car. In my case, I covered it with the 'ash tray/cup'. TBH, I would make something myself rather than going through a dealer. If you want to maintain the originality, fair enough, but try ordering a single insert and I think you may find it difficult!
Crikey £6.70 each plus VAT so £16.08 for two bits of foam. I think I'll look to cut some out of something else.
One of mine is missing, I assume it went the same way as yours?
I wouldn't bother with a new Fiat part, just cut some from rubber or such like..........that's what I intend to do.
Ian
I used some of that dimpled drawer lining rubberised stuff from Ikea.
But only coz it was laying around unused and I was getting tired of the coins jangling!
Some of the thicker rubber dash mat material might be better.
If anyone finds anything which is cheap and looks good, please tell, as I have no more Ikea roll.
I'd draw around the old ones. I must say that mine are pretty manky and feel quite crumbly.
Cheap rubber from eBay in sheets, use compass to measure diameter the draw circles. Got spares then if needed. The other panda hack is the rear boot pull. Open it up and twist the end inside out it can then used as a pull as was intended.
Just measured the cup holders in the Sporting - 65mm.
Which gave me one of those off-the-wall ideas.
For some interior bling, how about 65mm silicone wheel stickers?
Lots of designs, and only a few quid for 4.
Had some Fiat logo ones left over from when I was struggling to find proper badges.
Not much good on wheels, but look quite good at the bottom of cup holders. Just don't use the adhesive backing.
But a bit too blingy for me.
Guess I'll still be getting some black silicone sheet & a craft knife.
