Evening all.
I'm hoping someone can help !
I've been using the cigar lighter - auxillary socket in Nupanda for months to run SatNav and electric tyre pump. However, today whilst adding some air to the tyres the pump stopped. So, I rtfm and checked the fuse F44 iirc. There is no fuse ! Also there appears to be only 1 metal clip instead of 2 where the fuse would slot
Upon further investigation it appears that all the fuses in use have 2 metal insert clips for the fuse and the fuses which are not used only have 1 !
So, did FIAT forget to add a fuse holder for my cigar lighter - auxillary socket, or could this be fused somewhere else ? Ive checked everything else and nothing has stopped working. She's a 55 active (2006 model)
Not too sure whether removing one of the metal clip things in a unused fuse slot and bunging it where I appear to be missing one will work ? If this would work, does anyone have one they could send me ?? . . in return for a small donation to FF I'd be very grateful as I don't really want to start taking the fuse box apart.
I've seriously not been on the wine or anything else for that matter and the socket has been working since March !
Any suggestions appreciated.
Thanks all.
Thanks all.
