markofnorwich
- Jul 11, 2012
- 1
- 0
Just made the MP3 player connection myself and it does work well - much better than using an FM transmitter - even the Pace DAB radio that I was using before.
A few extra notes may help:
The Blaupunkt Audio in adaptor cable from Radio World on Amazon is a little short and only just comes out near the cup holder. I've bought a headphones extender cable to make the link to my iPhone a bit easier.
It's relatively easy to cut up this adapter with a craft knife so that it can used with the existing yellow plug but be careful not to damage the spades.
Feeding the cable down to below the gearstick is a bit tricky. First of all loosen the plastic panel underneath the gear stick, you'll need a T27 type screw driver; I got a kit from Halfords for £7.99.
Then find the route with a semi stiff rod of some sort, I used one of those bendy grabbers, which came out at the top left of the loosened panel. Then feed the cable back up to the radio aperture.
Then feed this cable through the back of the radio mounting bracket, so that the HU will return easily.
Then make the connections; the diagram on the back of the radio is for the radio itself not for the yellow connector. The Radio World cables are black (central, earth), red (top, right channel) and white (bottom, left channel). The spades will simply click into place. Make sure you get this right otherwise it means getting a new connector altogether!
Then pull the cable from the bottom, to where you want it to come out, slide the radio back into place and refix the the interior plastic panel.
Go to Aux on the CD button to play music directly from any MP3 source.
