| | Multijet - loss of power after cold start Hi. Recently my wife`s Panda diesel has had a major loss of power within half a mile of starting from cold. But in these days of electronic fuel injection on diesels, it could be anything. Has anyone had anything similar happen? I`m reluctant to involve Fiat until I have a better idea of what`s going on. BTW, the car is 2006 (56 reg ) and has done around 11,000 miles. Serviced at around 7,000 miles. Any ideas welcome.
__________________ Panda Multijet Skydome | ||
Posts: 1 Thanks: 0 Trader Rating: 0 | Re: Multijet - loss of power after cold start Hi , I have a fiat bravo 1.4 active sport, it is 1 week out and just the same as you it just cut out no power, when i tried to restart it the low fuel light came on even thou their is over half a tank of fuel in the car. the RAC had to take me home, i could have died.
| | #3 | ||
| | Re: Multijet - loss of power after cold start Hi I have had EXACTLY the same issues as you have just described. I took my Panda MJ (2005) back to the garage and they prescribed changing the mass air flow cylinder. Luckily this was done under warranty. It made no difference though!! Mine still does it after rain or underuse and I suspect that rain is getting into the airfilter and clogging it up. The engine will be starved of oxygen and will die untill whatever is blocking whatever has cleared. Thats my guess anyway - its as good a guess as Fiats as they couldnt fix it! i have written in more detail about it all in this link - hope it helps... http://www.fiatforum.com/panda-new/1...rly-panda.html
| | #4 | ||
Posts: 106 Thanks: 5 Trader Rating: 0 | Re: Multijet - loss of power after cold start Our MJ has done this occasionally from new - it now has almost 16,000 miles on. From cold within the first couple of minutes, it will sometimes die for a few seconds, then recover. There is a road junction about 75 yards from where I live - the favourite spot for it to die after a cold start. It's only ever stalled completely about 3-4 times - usually it just fades and then recovers without actually stopping. Never happens at all after the first couple of minutes. Weather conditions don't seem an influence - wet or dry, winter or summer. Reported this to the dealers on three occasions but there is a total lack of interest in sorting out problems which don't sport an error code.....
| | #5 | ||
Posts: 90 Thanks: 1 Trader Rating: 0 | Re: Multijet - loss of power after cold start I would say this really has something todo with the MAF sensors (air mass cylinder) on the car. Is the problem happening alot around full throttle?
| | #6 | ||
Posts: 1,391 Thanks: 39 Trader Rating: 0 | Re: Multijet - loss of power after cold start Another area that might be worthy of a look is the EGR valve which is responsible for recirculating the exhaust gases to reduce emissions. I've seen posts on other forums where a sticky valve can cause similar problems to what you're seeing. Shy of getting the valve fixed a lot of people try and block it off to prevent the exhaust gases being fed back into the combustion chamber (and as a result leaving sooty deposits in the manifold). Blocking it also improves performance too as you always only have "fresh" air in the mix. Chris
__________________ Holding up the traffic in a little Italian......... | ||
| | #7 | |||
__________________ Panda Multijet Skydome | |||
| | #8 | ||
| | Re: Multijet - loss of power after cold start I had my MAS changed by Fiat and it changed nothing!
| | #9 | ||
| Join Date: Feb 2004 Location: Manchester, United Kingdom.
Posts: 484 Thanks: 0 Trader Rating: 0 | Re: Multijet - loss of power after cold start I have had the same problem, I think it might be one or more of the glow plugs that have burnt out. I am not prepared to go to a garage because it is now out of warranty.
__________________ 31796 | ||
| | #10 | ||
Posts: 106 Thanks: 5 Trader Rating: 0 | Re: Multijet - loss of power after cold start I don't think it's glow plugs - I've had plenty of diesels, and the first indication of a failed plug is difficult or uneven starting. Mine fires up first time every time on all four cylinders - it's shortly after starting that it will fade. The EGR valve as mentioned by Scooby Chris sounds interesting - the first dealer to look at our car muttered something along the lines of " it could be the EGR, but it's not showing any error codes so we can't do anything about it". (This was on the first return to the dealer at 800 miles, with complaints of poor economy, engine cutting out after starting, black soot on tailgate and the intermittent death rattle which it still produces at low revs)
| | #11 | ||
Posts: 9,262 Thanks: 75 Trader Rating: 0 | Re: Multijet - loss of power after cold start Temperature sensor fault?
__________________ Pete. | ||
| | #12 | ||
| | #13 | ||
Posts: 1,469 Thanks: 28 Trader Rating: 0 | Re: Multijet - loss of power after cold start Let us know how you get on. I too have occasionally had similar problems with mine. I don't like the feeling of turning out onto the main road to discover I've got no get up and go (but if it goes that way on mine it's usually fine again within half a mile). A couple of times I didn't even make it out of the driveway and died a couple of times before getting going. Mine is just out of warranty, but I have had it into the dealers for checking on a couple of occasions before the warranty was up, and no error codes showed up.
__________________ The Northern Ireland Italian Motor Club. Find us at: http://www.niimc.net. We meet on the first Tuesday of the month in the car park at Prima Gusto, Harry's Road, Hillsborough just off the A1 at 7:45pm. Come along - All Italian motors welcome. PM me for more details. Last edited by Wee Smurf; 04-07-2008 at 13:15. | ||
| | #14 | ||
| | Re: Multijet - loss of power after cold start [QUOTE=Wee Smurf;1621441]Let us know how you get on. QUOTE] I took the car into Arnold Clark in Perth, and they have ordered a new air flow meter. It`s going to be fitted later on this week, so I`ll keep you posted. Meanwhile, the problem is becoming more frequent, and on one occasion, the car struggled to start.
| | #15 | |||||
Posts: 64 Thanks: 0 Trader Rating: 0 | Re: Multijet - loss of power after cold start [quote=pulhamdown;1642587]
It's been two weeks and no word: Any update on this? Had something similar like this myself back about two years ago and it was down to a fuel sensor (sorted under warranty - not off the road). Kinda wondering if it is the same for you. Stay safe. BJ 20
| | gortan | Cinquecento / Seicento | 4 | 04-01-2008 18:53 |
| 1.9d power loss | sciat fudo | Scudo | 3 | 21-10-2006 20:40 |
| | Bo~Select@ | Stilo | 24 | 07-03-2006 00:28 |
| | SCOOBYDO | Marea | 3 | 06-10-2005 19:39 |
| | johnwestisbest | Coupe | 7 | 16-03-2004 05:15 |
