Thread Tools
Old 30-06-2017   #1
2014 Panda Lounge 1.2
murphyv310's Avatar
murphyv310 has donated!
murphyv310 is an honorary friend of the forum :)
Oil catch tank.
Hi.
I have now lashed up a temporary fitment of the catch tank. If all goes well I'll get some nice alloy pipes made up and a proper bracket for the tank itself.
The main breather pipe was quite oily and the MAP was oily yet again.
I really think this will be a worthwhile modification.
Likes Alexiloki, jackwhoo liked this post
Cheers Trevor
murphyv310 is offline Reply With Quote Quote
Old 30-06-2017   #2
Goudrons has donated!
Re: Oil catch tank.
I'd be interested to know what it collects compared to mileage.
Likes murphyv310 liked this post
Goudrons is offline Reply With Quote Quote
Old 30-06-2017   #3
Re: Oil catch tank.
Quote Originally Posted by Goudrons View Post
I agree, it will be interesting to see.
Also have to give applause for the effective bodging using cable ties until you can fabricate a bracket. One of the most useful things I have in my toolkit
Alexiloki is offline Reply With Quote Quote
Old 01-07-2017   #4
Netherlands
Re: Oil catch tank.
There are pretenders among us.....
Geniuses with the ability to become anyone they want to be.
The Pretender is offline Reply With Quote Quote
Old 01-07-2017   #5
murphyv310's Avatar
Re: Oil catch tank.
Quote Originally Posted by The Pretender View Post
Nice if you're rich!!!!
Cheers Trevor
Old 02-07-2017   #6
Netherlands
Re: Oil catch tank.
Quote Originally Posted by murphyv310 View Post
Nothing to do with being rich or not, but just being the best solution IMHO.
After filtering it drain back into the oil-pan with this solution.
So no need to empty out the sludge after some time, just clean the filter and ready to go again.
Old 02-07-2017   #7
murphyv310's Avatar
Re: Oil catch tank.
Looks like a neat solution, two minutes draining the residue though and not returning dirty oil back to the sump to me is just perhaps more sensible.
Each to their own though.
Cheers Trevor
Old 02-07-2017   #8
Netherlands
Re: Oil catch tank.
Oil get filtered before that with this solution.
Besides that, where do go with the sludge that "you" drain. ??
Down the toilet. ??
You have to collect it somewhere and the get rid-of it environment friendly.
Back in the sump is a better solution IMHO.
Old 02-07-2017   #9
murphyv310's Avatar
Re: Oil catch tank.
Hi.
I have a 25 litre barrel I keep for oil changes and I empty it in an oil recycling tank when it's full, done this for years.
TBH I'm more than happy with my little tank, I've all the time in the world to potter about with the car and my other hobbies so it will do fine for me.
Cheers Trevor
Old 02-07-2017   #10
Re: Oil catch tank.
Educate me, what's the purpose of this system?
leroya500 is offline Reply With Quote Quote
Old 02-07-2017   #11
Netherlands
Re: Oil catch tank.
To keep your engine healthy.
Old 02-07-2017   #12
Re: Oil catch tank.
Elaborate with some science
Is it worth doing?
Old 02-07-2017   #13
Netherlands
Re: Oil catch tank.
Yes, everything from the blow by go's into your intake manifold and pollute it, with al kind of problem in the long run.
The Catch-can catch everything but air.
Google, Catch-Can Sludge and you have an idea what will not end up in your engine again.
Thanks leroya500 thanked for this post
Old 02-07-2017   #14
murphyv310's Avatar
Re: Oil catch tank.
Hi.
Every engine has to breath. The products of combustion and inevitable leaks past the piston rings would pressurise the sump and block if this small amount of pressure wasn't vented. In days gone by the rocker or cam cover would have an oil filler cap with gauze in it and the fumes would be vented to the atmosphere, some cars also has a breather on the side of the block.
Today due to regulations the breather fumes are vented back to the air intake on the throttle body side of the air filter and also a small bypass tube sucks the fumes below the actual throttle flap so the fumes will be burned on tick over.
What also happens is some of the oil from the engine as it splashes around is drawn up the breather pipe and it gets drawn in by the throttle and this collects in the inlet manifold. it will contaminate the MAP, carbon up the inlet valves and if excessive damage the Lambda sensor.
The Catch Tank literally breaks the breather pipe and oil will drip into the tank rather than it getting into the inlet manifold and engine. Both the inlet and outlet on a catch tank don't face each other for this reason, It is possible a tiny amount of oil still could be drawn in but that depends on the catch tank design.
Cheers Trevor
Old 02-07-2017   #15
Re: Oil catch tank.
Quote Originally Posted by leroya500 View Post
The idea is to prevent oil fumes/mist/vapour being sucked through inlet manifold.
The oil fumes etc could be contaminating the op map sensor causing poor engine running and possibly also being the cause of the op O2 sensor failing.
jackwhoo is offline Reply With Quote Quote
Thread Tools
oil catch tank rholtby Lets Talk FIAT 2 26-02-2009 23:16
(T) Oil catch tank Jamie Grande Punto 13 28-08-2008 10:06
(T) oil catch tank m_aver_ick Punto (Mk2/2b) 13 29-02-2008 00:42
(G) oil catch tank antsuno2 Uno 10 12-12-2006 09:46
will i need a oil catch tank.... Dunc Uno Turbo Leisure Lounge 20 05-06-2006 18:38
