Technical Panda 1.2 hill start problem
dinpitt
essex
Hi
I have just ordered a new panda easy + as fiat are doing a good finance deal on them. this will be my 4th panda altho I only have a 2008 diesel now( which I love) however I hadn't read about the hill start problems that the new cars have had and just wondered if anyone knows if the issue has been sorted or not?
Diane
Hi
Diane
hi, and Welcome Diane,:)
the 1.2 had a REMAP for engine emissions,
that had a limiting effect on some power requirements,
it's supposedly now been "fixed" on current cars - see 500 section for more info "Euro 6";)https://www.fiatforum.com/500/33982...sponse-hill-start-issues-watchdog-report.html
see after page#100 for current situation ,
Charlie - Oxford
Hi Charlie
Many thanks for your reply and apologies for resurrecting this thread. Am I reading correctly that if the car has ESP it should be ok now? Not sure if I should cancel the order.
Any advice gratefully received
Thanks Diane
We took delivery of our 1.2 Easy in March and it's been fine, so I would say you'll be fine. If you test drove a 15 plate car, then it should drive the same. ESP is now standard across the range.
Hi Diane,
I can fully sympathise with your position as unfortunately Fiat have been truly woeful in the way they have communicated this whole issue.
Funny how it went from the first Watchdog feature where they basically said it was down to driver fault, to the latest one a couple of weeks ago where apparently 850 or so cars have had the fault sorted.:rolleyes:
Have you actually test driven one of the latest 1.2 Pandas? If not, I would give your dealer a ring and see if they can sort you out with one, especially as you have a diesel at the moment. And definitely mention this whole hill start/Watchdog issue as well, it's important that they know why you are concerned.
In terms of whether the problem has now been sorted - the general consensus on that 500 thread is that new 1.2s registered now seem to be OK, so the likelihood is that you will probably be OK too. However, there is 100% no definitive answer from Fiat regarding this, and (I suspect) there never will be either.
As for cancelling though, if you like the car then I would hold fire subject to the info you get from your dealer. Hope you get the response you are looking for(y)
It seems from around the start of or early 2014, the 1.2 in the Panda's and 500's altered and quite a few owners have complained about a flat spot when pulling away.
It got as far as a BBC Watchdog report and Fiat commenting there's no fault, it's the way it's being driven.
After several Fiat's with FIRE's including our March 14 Lounge 1.2, a couple of 500 loaners (pre and post 14) and there still being a couple of pre 14 Pandas in the family, the later ones do seem to pull away differently.
It's believed to be due to the electronic engine management system.
It now seems it's linked to the clutch pedal, so when lifting the clutch the PCM will increase fueling to prevent a stall, it also smooths out gear changes as it blips the rpm when the clutch is about half way down.
I gather the trouble is two fold.
First, owners don't expect it and some just don't want it to do this as many are returning customers complaining their old one didn't do it!
Second is the way it works, the fuel and air on lifting the clutch is being controlled by the PCM, so lifting the clutch with no throttle input will see the rpms rise enough to pull the car away with out stalling.
It's so good at doing this it's possible on the flat to really motor along, changing up before the rpms are released or just sit in it going no where with the clutch half down and the motor pulling 1300 rpm at idle!
Now trouble with it flat spotting on hills I'm certain is due to driver input of the throttle while the PCM is controlling the fuel and air at the point of pulling away, so the PCM is controlling fuel yet the throttle body's air control is still effected by the drivers right foot!
With the drivers foot down the throttle body is open/opening, yet the PCM is still trying to contol matters, as soon as it passes control back, it bogs down due to lots of air, not enough fuel.
I can make our 1.2 bog for a few seconds as described above, then jerk to redline with a bit of whiplash as everything suddenly catches up.
I also get a big of "run on" when changing down under braking (something else they don't teach, see below), as when the clutch pops up, it's adding a dab of fuel/rpm and tends to make the car lurch a little.
I can also drive around it, just lifting the clutch fully up with no throttle pedal, feel the car move off and then start applying the throttle makes the whole problem smooth away.
This isn't a new thing, nearly all new cars tend to drive this way, even a couple of older ones do it, particularly diesels, but I think most now are "fly by wire" and do not have a physical link to the thottle body's "butterfly" valve, and as such can't be operated until control is released.
Recently, I've been made to feel like a bit of an old dinosaur.
My lad has been having driving lessons (obviously these lessons were in the intructors new car) and we bought him a little run around for practice, a rather rotten C2 (his choice).
The instructors car pulls away like new cars do, but the C2 won't, so there's been lots of stalling, huffing and rows!
I chatted with the instructor, explaining what's happening and he laughed, they just don't have to teach all the setting the rpms, feeling the clutch bite, releasing the handbrake stuff anymore, virtually all car's do if for them these days!
I'm now left trying to teach a stroppy teenager a skill he thinks is a complete waste of time and thinks he shouldn't have to do anyway!
Wow Goudrons thanks for such an informative reply. I too am a bit of a dinosaur and my daughter is learning to drive- has her 2nd test on Friday! She seems to manage quite well in my 08 multijet panda so I guess it's possible to adapt from old to new- just a bit easier when you are only 21!!
I spoke to the sales manager at the fiat dealer earlier and he has 'promised' me my car will be fine. However, he did also say that the people who had experienced problems in their cars were probably try to pull away in 3rd gear!! And no I don't believe that!!
I guess 'resistance is futile and I will have to adapt'
It is most definitely not definitively sorted for various people on the 500 page. There is also, as of yet, no concrete explanation for the behaviour outside of FIAT. The issue has repeatedly been shown (both on the affected 500s and by the total absence of these issues on every other EU6 petrol engine produced by every other manufacturer) not to be a case of "they all do that sir" or "it's a modern engine management artifact" or "****ing idiots who can't drive for toffee".
I wouldn't touch an EU6 1.2 with a bargepole, because if you do have the issue FIAT will leave you high and dry. It does not seem to affect every EU6 1.2. Having said that, we haven't had many brand new owners reporting the issue for a while.
Please read the thread: https://www.fiatforum.com/500/33982...sponse-hill-start-issues-watchdog-report.html before parting with cash.
Hi Zanes thanks for your reply
I totally understand your views so I wonder if anyone has a 15 plate 1.2 500 or panda that they would care to comment on. I test drove a 15 plate at the weekend which seemed fine but we didn't go up any steep hills. The entrance to the dealership had a short steep slope but I didn't have to stop on it.
As I signed the order paperwork on the dealer premises, I believe I have entered into a legally binding contract with them so am not sure if I can cancel it. At present I have paid £129 deposit.
I am very cross with myself as I thought I had researched the car pretty thoroughly prior to ordering one but I only discovered the euro 6 issue after committing myself
They'll be doing away with the manual gearbox next and giving autos as standard :p
That may well be the case MEP.
There's been a big step forward in the development of what we consider "automatics".
Almost gone have the a full slushmatic's and the god awful elastic banded CVT's didn't really set the world alight. (remember the DAF/Volvo 340's)
There are now replaced by automated manuals and I must say, the ones I've tried have surprised me.
OK, they can feel a little jerky to start with, but once you tune in to them, they aren't bad, particularly with some sort of hill hold device.
The models they are now fitted to are usually the cleanest and more fuel efficient too.
My old man's Citroen e-hdi Popemobile is amazingly frugal and doesn't Moo like a full auto either!
I must be getting dinosaur old, lusting after an auto!
I had a 2015 1.2 8v easy on loan and it was excellent, even better than the euro 5 ones. You can set off in most circumstances without any gas. I found it less jerky and had a better power delivery than the 2012 euro 5 panda which I have just sold
Always the way I'm afraid.
As you're buying on finance you may well have a cooling off period specified. I though there was a legally mandated cooling off period but I may be getting confused:
If you signed the vehicle order on premises and later change your mind, then the dealer is within their rights to keep your deposit – or at least any monies that they have spent on getting your car ready. But they can’t realistically force you to pay the remainder and take the car, so at worst you walk away having lost a few hundred or a couple of thousand pounds. You can fight them to try and get your money back, and if you battle long and hard enough you will probably get there, but it won’t be easy.
http://www.thecarexpert.co.uk/bought-a-car-and-changed-my-mind/ Check your paperwork.
Is this a stock vehicle or a factory order?
Thanks AAB1992 that is very helpful
Zanes the car was due to begin production the day after we ordered. I'm going to take a few days to mull things over. Thank you to everyone who has commented it is much appreciated(y)
Do not panic. My new 64 plate Dec 2014 1.2 pop drove drove exactly the same as the demo car. No problems. We ordered before the watchdog broke and rang up the dealer for a retest on hills. He said no probs, take the demo car for as long as you like. We did. It was fine. Ours was tested the same way on delivery and 5k miles later we love it.
I've got a 15 plate 1.2 Pop and I experienced something like this hill start issue once in the first couple of hundred miles. Hasn't recurred and I've done about 4,000 miles now.
I did notice the flat spot in acceleration at first, but I've started to work the engine a bit harder now that I've had it a couple of months and it isn't so much of an issue.
Quick update. Picked up my new beastie today and I am very pleased with it. So far had no issues altho only done 80 miles so far. Many thanks for all your comments and good luck to those still trying to sort out issues with their cars.
Am I right in thinking that the car should confidently pull away without any gas, as would a more powerful car without some sort of clutch/gas compensator? Such as my mothers Ford Street Ka 1.6 (did a fair amount of hours practice in this) or my driving instructors diesel Vauxhall Corsa (11 lessons to passing)?
On my test drive (63 plate, 4k miles, POP) I stalled about 5 times :doh:, but I could potentially put that down to being a brand new driver?
I have tested mine on quiet flat roads and it does generally struggle, or stalls if I'm slightly too quick to lift the clutch. I'm just wondering if I should be expecting more from my Panda?
No, only an automatic should do this and creep, most modern cars are capable of pulling away with no throttle, but isn't something it should be capable of doing in all circumstances.
A Diesel will be better at this due to its torque.
