Right since getting the Selecta I have been reading as much as possible about it.
Not anything to do with what I am about to ask, but I can now def give an answer to whether you can tow a selecta and the answer is YES but for no more than 16 miles and at a max speed of 20mph any faster & longer distance can damage the box.
On to my selecta and I am confused as hell to be honest. When I start the car which runs lovely I put it in D and unless the little red light comes up on the panel by the lever it will not engage drive. However I have the same symptom in L unless D has already been selected, then even if the red light doesn't show in L it still engages. When in reverse again unless the red light on the panel comes on it will not engage and this is anytime no matter how many other gears have been selected.
Finally there is no light that comes on when in P (I assume the bulb has gone) and gives me the beep/buzzer when I open the door to say it is not in P even if it is.
By all of this I take it the lights on the panel do have a significance to the opperation of the box or the contacts to illuminate these and select the gears needs an overhaul and clean up.
Can anyone shed any light on this or is this Selecta being affected by the McDonalds ghost of Christmas past ? Or should I phone Minty and ask WTF he has being doing to it on EastEnders
