MarbellaLT
Hello,
I'm repairing my Marbella brake system. Well acutually I'm renewing everything
As you know there is pipe from master cylinder to pressure regulating valve and from Pressure regulating valve to rear brakes. Well in Marbella is a little bit different valve than in Panda but it's not important.
Does left and right sides valves are the same?
Maybe anyone tryed to remove that valves and connect pipe from master cylinder to rear brakes without valve?
I'm thinking to do this because I can't get new valves, maybe it won't be very bad without them? Maybe rear wheels won't lock when I push brake pedal?
Thanks.
Thanks.
