Thread Tools
Old 4 Weeks Ago   #1
No dashboard lights or indicators.
Hi, just wondering if anyone has experienced a similar problem? Driving along this morning and my dashboard lights suddenly went off, then I discovered that my indicators weren't working, the headlights and break lights do still work, but nothing else. Had the fuse checked and they're fine, took it to a garage and the mechanic basically said he hasn't got a clue. Anyone have any idea what the issue could be? Only had the car 2 weeks! Also, the stereo isn't factory fitted, so can this be part of the problem? Of I use the radio, the engine cuts out when sat at lights. Thanks
Vikki1 is offline Reply With Quote Quote
Old 4 Weeks Ago   #2
renaultvation has donated!
Re: No dashboard lights or indicators.
Bit of a long shot, but I seem to recall a similar problem on our Cabrio many years ago. The speedo and rev counter also stopped working as did the front windows. Turned out to be a fault with the ignition switch which was resolved by wiggling the connector until everything worked, then holding it in place with a cable tie. A bit of a bodge, but that cable tie is still doing its job many years later.
renaultvation is offline Reply With Quote Quote
Thread Tools
(T) Electrics - indicators and dashboard knackered bigredtone Bravo / Brava 5 10-04-2010 21:40
(T) Car dashboard has died (and no indicators / brake lights) duncan32 Marea 3 06-05-2009 20:02
Brava 16v automatic dashboard indicators. Vinnie FIAT Boo Archives 2 22-09-2006 11:40
dashboard indicators description -mj- FIAT Boo Archives 3 07-10-2003 19:40
