Lamps by Post - For all your lighting needs
Thread Tools
Old 16-02-2017   #1
Hello and help with indicators - Multipla
Hi all, I have been reading a lot of posts on here after getting my Multipla
Now, I have an issue (shock, I know)
The indicators on the left hand side are sticking on, all three, even with the ignition off, for now I have removed the hazard warning fuse so they dont work and neither does my remote. (indicators still work)
I have changed the flasher relay and this has made no difference.
Help please
05 newer shape 'pla
Andy
filter99 is offline Reply With Quote Quote
Old 16-02-2017   #2
ArthurM has donated!
Re: Hello and help with indicators - Multipla
Hi. You could try taking the rear light cluster off and cleaning the unit getting rid of any crud(grey coloured) using a BRASS wire brush.Take out all of the bulbs ,not just the indicator one and give a good clean ,also clean inside of the bulb holder. Then clean the connecter. You can give it a spray of WD40.I tend to use a small amount of good copper grease.
ArthurM is offline Reply With Quote Quote
Old 16-02-2017   #3
Thank you - I shall give this a go, just have to climb into the boot to open it lol, needs a new switch assembly, when i bought it, it was broken and rattling around lol
Old 17-02-2017   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Are you sure the hazard switch isn't at fault?
D
Old 17-02-2017   #5
someone else mentioned that - now the question is - how do i get that off to check eep
Thread Tools
M6 mirrors with indicators, anyone wired the indicators up before? seb FIAT Boo Archives 9 29-12-2006 12:34
