Jonathan2014
- Dec 3, 2014
- 3
- 1
I have a fiat stilo 1.6 54 plate I brought it back in September this year it ran fine for a few weeks and then the problems started it struggles to pull off kangroos which causes problems when pulling out stalls constantly revs bounce up and down when ticking over and drinks fuel the on board computer tells me I'm getting 14 mpg! I had it plugged in to a diagnostics and was told clean throttle body which I done still didn't solve it had it plugged in again was told to replace 02 sensor and map sensor which I did still hasn't solved it I have also replaced spark plugs and air filter and after all of this it seems to be getting worse really Carnt afford to keep buying parts that don't solve it this close to Christmas would massively appreciate if any one had the same problems and resolved it thanks!
