Now can someone help ME !!
My engine stopped. But there is no MIL light on.....I think the ECU is not getting power....my MaxiDiag gives "linking error"....I conclude it can't talk to the ECU...because the ECU is unpowered, or dead !!
After replacing the brown Bitron multifunction relay, checking fuses, earths, connections into the engine compartment , the inertia switch behind the reservoir on the LHS, I have disconnected the ECU, and measured all the voltages at the supply pins.
I get weird voltages from 1/2V ...6 1/2V....and so on up to 12V.
I am going to check my battery positive connections because there are several crimped leads at the terminal which might be corroded.
Any advice....I am stuck in France !!
