Grill problems
Grill problems
Emmalouwalsh1989
I had a small bump in Nov and my front grill has been a bit pushed in at the bottom but connected at the top. My boyfriend tried to fix it and unfortunately made it worse, now i have had to take the grill off completely!
Does anyone know if the grill can be put back on without taking the front bumper off?
I am taking it to a local car garage this afternoon but just wanted some quick advice beforehand.
Hello. I've had exactly the same issue. Did the garage have to remove the bumper?
Tim
Sorry, can't answer your specific question, although I suspect that for access purposes, the job would be significantly easier if the bumper was removed - it's only about 10 screws and 2 click connectors.
As a stop gap ( and part of the bumper removal process anyway) removing the front section of the inner wing liner might allow sufficient access to do the job anyway.
Either way, worth trying before you have to fork out for an hour's labour (and I suspect your BF will settle for a non cash reward anyway.......)
