Demipatten
- Jun 20, 2019
- 4
- 0
Hi sorry to bother you again but the code hasn’t worked :/Thanks for donating to the forum.
your code is: 4164
your code is: 4164
PLEASE can someone help quickly as we are off for a weeks driving holiday and will have no radio! Details are BLAUPUNKT Fiat 223 CD SB05 7 646 331 316 e1 034501 and 815BP633165617916 and FIAT-Nr 735435 139 0 Thank you
Hiya
I'm new to this site. My daughters Delphi cd radio has broken and would like to know if any Delphi radio of the same make and with a code will work
The 10 digit numbers are different but everything about the two radio's is the same.
Thanks for that.Providing all the other numbers on the replacement radio are the same, then it should work.
Thanks for that.
The one I'm looking to buy has different numbers :- HW VER:28302823
7355354400 to the original that's broke, as I would expect, but it's the same generic radio but is applied with a code.
The original radio and code would from what I've read be stored in the cars computer, so when the replacement is fitted the new code should then override this?
Thanks again
Yes.... once you've fitted the replacement radio and entered its code, then the new code should replace the original code in the car's body computer.
A different hardware version (HW VER) shouldn't be an issue.
try this code 5415![]()
Hi, wondering if you could please help me figure out my code.
7646383316
815BP638389514088
Many thanks, i have donated![]()
Hello,
Have you a code for this one please
815CM8572A9023106
7 648 572 316
Can you get the code for 815BP639886120978
7646398316
lANCIA 843 II MY C1V2 MP3
Hello, can anyone help me with a radio code?
BP-nr. 7 646 386 316
Fiat-Nr. 735 434 952 0
Fiat 169 C1V2 MP3
I understand that I have to make a donation and that is what I will do.
Thanks in advance,
CorJ
