The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Hi Davren,
it would be amazing to get the code for my Multipla's radio:
BP333142223666
BP - Nr: 7 643 331 316
Fiat - Nr: 735 391 102
I have donated to FF just now.
Thanks!
Worked like a charm.
Thanks so much.
I am curious about how you reverse engineer the code from the serial numbers. Is it something you can share, not the details but just the principles?
You mean a simple file/database that contains the mapping between all serials and activation codes?
Sounds like a panama-leaked document.
Great to have it at hand though :D
Thanks!
I'm new to all this and was looking for some help!
I need to find the code for my fiat scudo radio 94 plate
Serial no. CL040140966998C
P.U. 2294A
Thanks in advance
Ian
P.U. 2294A
Thanks in advance
Ian
Thanks for such a quick reply Davren.....
The number is C70000006165
I have the code for your radio.
Click the link below while logged on to the forum.
https://www.fiatforum.com/donations.php
Do not use the anonymous option to donate.
Code for a connect nav
Hi, just got a nice black connect nav to replace my damaged connect nav.. It came from a scrapyard...but there was no codecard...How do i get a code for this connect nav radio?
Fiat Stilo Abarth
imei 500189440096780
type 735297003
2G6D0W5BC
C 141
CE 0681
is what i found on this radio
thx in advance
