Ok Guys, Just joined the forum as a friend of mine is having problems with his aftermarket head unit. The situation is as follows...
Installed Pioneer navigation/multimedia head unit, the unit is up and running but when he goes to use the satnav it states that there is no speed pulse signal and so the unit will operate in hybrid mode. So, he purchased an interface lead which is a connects2 model which he was told was the model he needed. The first problem is that when the lead is connected the unit will not power on. This was solved temporarily by taking a feed from elsewhere. So his current problem is that there is no speed pulse supply. All the bullet connectors are plugged in in accorance with the supplied diagram but it is still reporting no speed pulse. There are three iso connectors comming from the car and all three are plugged into the supplied iso harness. Any ideas and help would be appreciated?
