Cleaning and reassembly
I used a scrubbing brush and hand cleaner, washed off with hot water, and then compressed air to dry each part.
You might alternatively use a brake cleaner spray can, particularly if you don't have compressed air handy. The brake cleaner will help to disperse and evaporate the water that you're trying to remove.
It is probably not a good idea to force-dry the cards by heating. If you do, be fairly gentle with a heat gun - no open flames! - and no, putting them in the dishwasher is probably not a good idea... well, all right, maybe the top rack - just as long as they can't fall on the element
You will notice that each card has a number. There are four layers in total, including the grey back part.
Be careful that the bars at the edges of some cards are kept concentric (should not touch) - make sure each card is pressed down fully before adding the next.
Now it is time to refit the electrical terminals. This only takes a few minutes - but then you realise there aren't enough terminals to push onto all the spades
Make sure the large copper terminals go on the same way as before - otherwise, the maxi-fuses won't engage with them (don't ask how I know this) :bang:
Each relay has one type of terminal for the pins that face one way, and the other type of terminal for the pins at 90 degrees. Please see the photos below (or the ones you took before you pulled off the terminals...)
The final step is to carefully refit the front - guiding the terminals into their slots - you might need a narrow screwdriver to gently help the smaller terminals into place.
Snap the two plastic halves together as tightly as you can.
Re-install the fuses and relays (easy when you have a photo; see photos below as well. What did we do before the days of digital cameras... wait an hour for the film to be processed?
Re-install the fusebox in the car. Make sure the red wire hasn't come out of the middle plug on the back - its crimp wasn't the best on the subject car and it had to be re-done.
That's it - pretty simple, but satisfying when all of those confusing symptoms disappear - the Selespeed pump comes back to life - and no more flat battery overnight, I hope.
