1. The boot liner plastic has got two pokets with a hex bolt in them. Remove the bolts than grab the plastic at one corner ant nicely prise it away from the door.
2. Find your lock and undo the 2 10mm bolts, than undo the rod from the little white holder by turning the plastic counterclockwise. Now you can take your locking mechanism inside your house and carry out the rest of the job there
Disassembly of the locking mechanism
1. Remove the plastic bit that is around the keyhole.
2. Around the middle there is a ''cut'' in which you find a spring, remove it
3. Turn around the lock and remove the little circlip ring and the end plate from the tip of the shaft.
4. Remove circlip than the washer than the shaft that are inside of the barrel.
5. push down on the black plastic bit while trying to push it through the hole once it has moved out of place remove it, than remove the inside ''barrell" bit. Look out for the spring not to shoot off anywhere!
6. Now you should be left with only the shiny bit of the actual lock barrell poking through the middle of the whole housing. Put it in a vice or in between two logs of wood or bricks or something solid and same height object. put a screwdriver onto the shiny end and gently tap it with a hammer. It should easily come out from the housing. Does it not? You did not forget step 2. Did you?
7. I put mine in 20% spirit winegar which destroys lime that is causing it being seized and after a day it still was not clean and badly corroded, but if you put the key in yours and the little claws retract than you are done you can reassemble everything in reverse order starting from step 6.
Or try and agitate the little sliding reeds with a flathead screwdriwer and the gentle tapping of a hammer while trying to blow out the built up dirt.
BEFORE REASSEMBLING CLEAN EVERYTHING WITH BREAKCLEANER AND REGREASE THE WHOLE UNIT TO AVOID WATER GETTING IN AGAIN.
Lock barrell badly damaged
If your lock barrel badly damaged you can still fix the whole unit.
Get a working donor lock from a breaker.
Disassemble it as written above. When you managed to get hold of the actual donor lock barrell you continue like this:
Insert your key into it, you will see that some of the reeds retract some of them not. Grab a file or dremel and make them flat with the aluminium barrell, you might need to poke the reeds from underside to get more access, when done put it back in the housing with your key and try if it is moving freely.:slayer: If yes reassemble it AFTER CLEANING AND GREASING!!!
I hope this helps you out guys if that is the only major problem of your stilo's
