Refit shaft
Align inner boot with tripod.
Ensure the end of the CV is kept clean and there is no debris on the hub. This is to ensure no damage occurs to ABS sensor.
Fit inner joint and outer to hub.
Refit suspension joint and steering joint.
Refit Plastic covers
Fit wheel and driveshaft nut. Wait until the wheel is back on the ramp before making sure the driveshaft nut and wheel nuts are tight. Knock the tag with a punch so it can't come loose.
