Thread Tools
Old 1 Week Ago   #1
Electric window drivers side broke
My drives side door electric window has broken. I took the door panel off and the metal wire inside is messed up. Is this easy to fix. The plate is 56
Scott
Sent from my iPad
Scottdole92 is offline Reply With Quote Quote
Old 1 Week Ago   #2
Re: Electric window drivers side broke
yes fairly easy to fix.
You can buy a repair kit (wire, pulley) but very fiddly to change wire much easier to get a used regulator complete off e bay about 30.
About half an hour to swap over.
ratbag is offline Reply With Quote Quote
Old 1 Week Ago   #3
i had this exact same problem a few weeks ago. i was going to try and repair by replacing the wire with a new one, but it was too fiddly so i just bought a whole new regulator off ebay for about 30
if you've taken the door panel off, you're half way there already. remove the insulating foam and look for the bolts holding the regulator on (there's three). the window glass is attached to the regulator using a orange clip. you remove the clip like so:
i'm a complete newbie to car repairs and i managed
from my research, all the regulators are the same (all years, 3 door/5 door doesn't matter). just need to make sure you get a drivers side one
oldmanhouse is offline Reply With Quote Quote
Thread Tools
(T) Drivers side Electric Window topcat5 Doblo 14 07-01-2011 01:56
Electric drivers side window gemmjohn FIAT Boo Archives 6 01-09-2010 23:51
(T) Electric Window drivers side not working. thefallenangel Punto (Mk2/2b) 0 23-01-2010 17:42
(T) Drivers side electric window meaton Multipla 6 19-09-2009 18:38
Electric window switch drivers side window switch has busted the passenger side is working but the a Ricky FIAT Boo Archives 2 20-11-2007 20:57
