Hi Nelson,
the controler checks what current goes to the 4 glowplugs; if one gets open, less current is drained so the controler would tell the ECU there is something wrong (via one of the signal wires, pin 2 or 5), the ECU will then tell the dashboard to flash the glowplug light... Looks that's what your car is doing.
You should replace the defective glowplug and your preheating circuit should be back to life as normal. Be carefull those glowplugs are extremely brittle !! You've be warned ;-)
- have the car in your garage
- stop the engine
- gain access to the glowplugs (remove air-box)
- let engine cool down completely
- spray WD40 or your preferred unseizer stuff on the plug thread
- leave it for the night
- next morning you should be able to remove it WITH THE RIGHT TOOL ...
- install the new one (copper unseizing paste on the thread is a good idea)
- reconnect wire(s), re-install air-box
- ignition ON, pre-heat light should pop-up at dashboard for 8sec
- if so you're done !!
Regards, Bernie
Hi Bernie
Ok that makes sense, will get the glow plug replaced over the next few days and let you know. Thanks for all your help!
