- Sep 10, 2015
- 22
- 8
Hi guys,
I have a bit of a problem with my coolant temp sensor circuit.
My car threw a check engine light and error code "P0115 Coolant Temperature Sensor Circuit Malfunction" earlier. I replaced the sensor itself with a brand new item, and checked the wiring etc for any potential ground and came up with nothing.
The new sensor didn't solve the problem, and when I try and clear the fault code, it just returns immediately.
I've checked out the temperature sensor values on MultiEcuScan and the coolant temp sensor reading seems to be ok - started off around ambient and gradually rose to 70 odd degrees C, all whilst the engine light remained and wouldn't clear.
What is strange though is once the car is up to temperature and the coolant temp gauge is at half way, if I turn the car off and straight back on, the coolant temp gauge resets itself to zero and takes a while to rise back to mid way - but the reading on the diagnostics is still showing the correct figure. Usually the temp gauge would just return to the correct half way point on the gauge
The car feels like it's in a safe mode as it's definitely down on power. It struggles a bit to start when warm too, which to me seems like the engine may be over fuelling as it thinks it's doing a cold start.
Anybody have any ideas what this might be? Could it be ECU related? I'm at a bit of a loss.
Thanks.
Thanks.
