Morning apologies that my first post is asking for help but I'm running out of idea's with a problem with my 2007 T Jet.
When you turn hard left at speed (or low speed while accelerating) you get a nasty grinding/rubbing noise on drivers side. I have a sound clip which hopefully will demonstrate this better than describing but cannot put link in yet as not got 5 posts - happy to share if anyone wants to hear this
So far I have tried 2 driveshafts - one cheap new one and a used low mileage Fiat one with no difference. It doesn't sound clicky like a CV joint in my opinion. I have also changed the top mount on drivers side and new drop links both sides.
The bearing does not have any play although I did think possibly the bearing could be failing under load. I have not noticed any normal bearing noise while driving so not sure about this.
I have also firstly bent back and then totally removed the drivers side brake dust shield in case this was rubbing but no difference.
Does anyone else have any other idea's?? shock? The discs are lipped slightly but I cant see anywhere where its been rubbing. I've also looked under the wheel arch and cant see any tyre interference
thanks in advance :bang:
Lee
Lee
