Andy In A Grande
OK, so I have posted at the bottom of another thread, but I havea couple of niggles with my GP that have been going on for a while (they are just niggles, but can get REALLY annoying sometimes lol) so I'm hoping some of you good guys here can help me out. So the problems 'niggles' I'm having are as follows:
1: AirBag light is always on. seems to be since I changed to an aftermarket head unit and installed amp and sub (6x9's there also but not installed cos the parcel shelf has a metal bar running through, so not so easy to cut :|).When I installed the ICE I used a scotch clip to the 'cigar lighter' under the gear stick gator for power source.
2: Around the same kind of time, i have had problems with the car starting. Its starts Id say about 90% of the time, but every now and then it just doesnt. the dash will illuminate, and the head unit turns on etc, but literally no noise whatsoever coming from the car, sometimes I leave for a while and retry and all is fine, other times I use the wifes car, and jump it, usually does the trick lol
lastly, the 1 already mentioned on another thread, is my fan blower, went out this morning, to warm car up before loading kids for a school run, the car heated up, but the windows misted up like crazy with the car fully loaded, tried turning the fan on to demist, and seemed they werent blowing anything. however the car was warmed up, so must have still been producing heat.
I have since gave a bang on the trim in passenger footwell (literally, banged the plastic) turned the car back on, tried fan heater, and is working now, but only on setting 1/2/3. nothing at all when switched to setting 4.
Im sure these are all going to be a straight forward fix (im no mechanic, but am good at following instruction) and as I said earlier, they are all just niggles as each problem has a way around it lol
