Hi I noticed with the colder weather my rear lights are steaming up inside, mainly the indicator part. Does anyone know if you can buy the bulb holder seal from the dealers or any other reason why this might be happening? Thanks.
My rear passenger side keeps getting like that! It fills up with water also, loads of water in the bottom of my cluster!
All iv done is empty the water out, then got a hairdryer and blown all the condensation away, you could probably sit there for a good half an hour until it goes but eventually will go!
Then put some vaseline or something around the seal!
