As Ziggy suggests, blue pipes are normally the fuel vent pipes. Somewhere along the line, possibly under the front wing, or near the fuel tank, will be a canister containing carbon. This holds the fuel vapours and allows the tank to breathe without fuel vapours escaping to atmosphere. There will be a purge valve that allows the vapours to be drawn into the engine to be burnt, once the engine is warm enough.
With the pipe holed, the vapours will escape. You may get annoying petrol smells in the cabin. When the purge operates, it will suck air into the inlet manifold instead of fuel vapours, causing it to run weak. The lambda sensors will identify the weak running, and the ECU will richen it to compensate. This may just cause higher fuel consumption, or it may light the engine management light.
Any fuel resistant tubing can be used to repair it. Your local car accessory shop should be able to help, hopefully with a couple of in-line connectors, so you just replace the chaffed bit.
