Stifler3513 New member Joined Mar 20, 2013 Messages 181 Points 48 Sep 8, 2014 #1 Hi just wondered if you can help as my gearbox is stuck in 2nd the gear stick feels like it isn't attached to it. Would this be the selector
cmosfxx Established member Joined Apr 3, 2012 Messages 1,365 Points 263 Sep 9, 2014 #2 Maybe cables? Get someone to change gears and check if selector is moving.
A aurick86 Established member Joined Sep 14, 2009 Messages 2,068 Points 459 Location Bucharest Sep 9, 2014 #3 Yes this sounds like a cable problem. At best one of the cable ends just popped off the ball-end, you can slip it back on and try securing it with something. At worst one o the cables is broken... which would mean a new cable set.
OP OP Stifler3513 New member Joined Mar 20, 2013 Messages 181 Points 48 Sep 9, 2014 #4 The cable was broken unfortunately. Means I haven't got a car for a couple of days . Just wondered would around £200 for the repairs are about right
A aurick86 Established member Joined Sep 14, 2009 Messages 2,068 Points 459 Location Bucharest Sep 10, 2014 #5 I think the cables are around 200, then add the labor.... so be ready with 300
OP OP Stifler3513 New member Joined Mar 20, 2013 Messages 181 Points 48 Sep 10, 2014 #6 Ok bud the mechanic said it's gonna be £200 all in so that's cool
