DrumRollChris
- Nov 18, 2013
- 194
- 41
Changed the oil + filter a few weeks ago and noticed what looked like bubbles on the inside of my expansion tank. Checked last night to find the coolant level below the minimum. Not sure if that would indicate a head gasket problem or even a cracked cylinder case (quest case) or just the coolant boiling over. After checking the nick of the oil and the filter I don't think the coolant has been changed anywhere near the service time. It's still clear and doesn't look like it is contaminated. If I feel like there's no mechanical faults, just the coolant boiling over then I'll go ahead and do a flush and coolant change. Any thoughts/ideas would be much appreciated. Should point out its just about to hit 95,000 miles.
