Dfdm
- May 13, 2013
- 14
- 5
Hi everyone,
I know this topic has been done to death but I haven't found an identical problem:
My heater fan used to blow really gently, and would sometimes stop and then start again if I drove over a speed bump or gave the dash a little thump above the central console.
Now, the fan does not blow at all. However, the temperature control works fine. (Air enters when moving at speed).
Is it the motor that's bad or is it more likely to be the resistor/wiring?
It gets rather cold here in winter, making driving with misted windows rather interesting... I've spent the last few months using a squeegee on the inside of the glass, til I can afford to get it sorted!
Cheers,
Rob
Cheers,
Rob
