I need to know the difference between the rear axles on grande puntos.
I need a new one and the only difference I can spot is the bracket to hold the brake lines for calipers wheeras the drum versions dont have the bracket, but still have the holes to rivet it in, this leads me to believe all the rear axles are the same...
However, on a new version of EPER I have found, it says they are different http://cerivensrl.com/navi?SGS_COD=...ROUP_7&SB_CODE=-1&WINDOW_ID=1&ALL_LIST_PART=0 It says my car is an M89 but says the one for a 1.4sporting is a different part number.
Is there actually a difference?
I refuse to believe Fiat would put different beams on the car just because of a different engine, springs and shocks yes but not the whole rear axle.
I have found a 1.4sporting that is being broken due to a front end smash and I may be able to get the rear axle off of it, but I need to know if it will be ok on my 1.9mjet.
Thanks for reading
Adam
Thanks for reading
Adam
