The FIAT Forum
  • Forums
    New posts Featured threads Search forums Members list Members map
  • Guides
    New guides Latest reviews Series list Search guides
  • Downloads
    Latest reviews Search downloads
  • Garage
    New vehicles Latest content Latest updates Latest reviews
    Series list Search garage
  • ePER
  • Events
    Monthly Weekly Agenda Archive
  • Gallery
    New media New comments Search media
  • Classifieds
    New listings
  • Directory
    New businesses Latest content Latest reviews
    Brands Search reviews
  • Shop
    Latest reviews Search products
Log in Register
What's new Search
Search
By:
Advanced search…
  • New posts
  • Featured threads
  • Search forums
  • Members list
  • Members map
Menu
Log in
Register
Install the app
  • Guides
You should upgrade or use an alternative browser.
Grande Punto rear lights conversion to EVO lights
Grande Punto Grande Punto rear lights conversion to EVO lights
  • Thread starter MKoers
  • Start date Jun 17, 2012
Guide Gallery Discussion
I just fitted my EVO lights in my Grande Punto, as there's no guide yet I made a couple of pictures to create one.
I hope'it's usefull for anybody who waht's to fit EVO rear lights.
Next page: Needed tools >
  • Thanks
  • Like
Reactions: Andy Monty, gi_viper, Anagi and 3 others
OP
OP
MKoers
MKoers
Patron member
Written a guide
Elburg
  • Jun 23, 2012
  • #2
Figures out what the best option was for the resistors to remove the error from teh dash.
I cannot edit the guide?
I put to 25watt 8Ohm resistors with heatsinks in a serie.
So they will use 50 watt's with a resistance of 16 Ohm.
This has been put between the LED+ and the MASS.
They become hot but I can put them in my fist without burning myself.
I do have two huge blisters from the solder iron though...:eek:
  • Like
Reactions: Anagi
W
Woodruff
Crowborough
  • Jun 24, 2012
  • #3
These Lights look so so cool. just ordered everything I need! Thankyou for the guide!
W
Woodruff
Crowborough
  • Jun 29, 2012
  • #4
do you know where i can buy the plug for the 'evo' lights? and what is the mass cable for?
M
MIC137
GP power
Fgura
  • Jun 29, 2012
  • #5
punto mk1 plug is the same mate if you don't find :D
my question is if the resistor is set in series or parallel to the led wire. thanks
W
Woodruff
Crowborough
  • Jun 30, 2012
  • #6
You're 100% sure the plug from the mk 1 will fit the new evo lights? with the 5 metal bits? thanks
W
Woodruff
Crowborough
  • Jun 30, 2012
  • #7
mate do you have ANY idea where i can buy these rear plugs?!?! im desperate!!
OP
OP
MKoers
MKoers
Patron member
Written a guide
Elburg
  • Jul 1, 2012
  • #8
I got the plugs from an Gp EVO on scrapyard.
OP
OP
MKoers
MKoers
Patron member
Written a guide
Elburg
  • Jul 1, 2012
  • #9
The resistors are placed parallel to the led LED wire.
So straigh between the + and the MASS cables.
W
Woodruff
Crowborough
  • Jul 1, 2012
  • #10
is the load resistor wired like ..... LED Wire - LOAD RESISTOR - LED Lights
or is it... Mass wire (black one i believe? if 'mass' means like the main power one?) - Load Resistor - LED lights...
Is it either one of these combinations?
Mass Wire - Load Resistor - LED lights...
I've tried cutting the LED wire and placing the Load resistor inline with it but it's failed. please help!! they look great btw, thankyou muchly for the guide!!
OP
OP
MKoers
MKoers
Patron member
Written a guide
Elburg
  • Jul 1, 2012
  • #11
MASS is the Ground Cable.
It's placed parallel to the led.
So you put the resistor between the MASS Cable and the + Cable.
You can see on the photo's on the guid how I wired it up.
A
abhidesign
  • Nov 20, 2012
  • #12
Nice job... i like that, How can i get those EVO rear lights for my GP?
T
Touchybabybee
  • Jan 24, 2015
  • #13
I have just purchased some rear evo lights the the plug I currently have is the 5pin square plug, I need to get hold of the 5pin round plug, anyone know where to get these from otherwise it'll be a soldiering an spade job! :mad:
vivekrj
vivekrj
Written a guide
New Delhi
  • Feb 3, 2016
  • #14
Hey bro I am bothering you on this installation again,
Actually I am also trying to install it here in India.
What I came to know is that the resistance of the Parking light bulb is approx 3 Ohm.
And I am having hard time searching resistance of proper specs.
Please help me for some kind of alternative way.
E
ener
  • Jul 12, 2016
  • #15
Hello, what is the name of this part (in the green cyrcle) and where can I buy it?
anyzunstudios
anyzunstudios
Grande Punto "FastLine"
Parked in the garage
Spain
  • Apr 26, 2018
  • #16
I think that Brown/Black on left plug and Purple/Green on the right one is for checking LED conditions, I mean, check if they are blown or grounded to mass. Of course, we don't need it on our GP unless we want to check LEDs, so maybe you will need an extra homebrew board to check signal and send it back to ECU. Maybe using a MCU like the dear Arduino voltage sensor and a relay it might be able detect it, and then cut the LED power signal for avoiding damage ECU, wiring, or fuse system, and the Body Computer will detect that anomaly and show our detested "Check Running lights" message on our dashboard.
By the way, great job. On my EVO tailights, wiring color are different of yours, but I was able to make it work. If you want to remove the message on the dashboard, you just need to get x2 "5 Ohm" load resistors like (creating less temperature due to better heat dissipation) only on the driver side (on british cars) or passenger side (on the "common" cars).
Greetings and thanks!
Julio.
You must log in or register to reply here.
Similar threads
JumpJet
  • Guide
500 (Classic) Dynamo/Generator to Alternator Conversion
  • JumpJet
  • Mar 29, 2025
Replies
2
Views
366
Mar 31, 2025
124BC1
1
Redeagle
  • Guide
Grande Punto Fiat punto multi jet 1.9 gearbox common noise
  • Redeagle
  • Nov 8, 2024
Replies
2
Views
481
Nov 10, 2024
Redeagle
Redeagle
T
  • Guide
Ducato How to determine if my engine has been deleted
  • theoneandonly
  • Dec 5, 2024
Replies
Views
327
Dec 5, 2024
theoneandonly
T
R
  • Guide
Ducato Automatic rear camera activation on Ducato 2023/2024 left steering wheel
  • roulemapoule
  • Mar 24, 2024
Replies
1
Views
622
May 2, 2025
frederic34
F
Pugglt Auld Jock
  • Guide
Miscellaneous Cheapo jump leads - how to "improve" them and use them
  • Pugglt Auld Jock
  • May 22, 2024
2
Replies
28
Views
1K
May 24, 2024
chris3234
C
Share:
Facebook X (Twitter) Reddit Pinterest Tumblr WhatsApp Email Share Link
  • Guides
  • The FIAT Forum
    fiatforum @fiatforum
  • About The FIAT Forum
    The internet's #1 online community and oracle for all things FIAT since 2002 - if we don't have the answer, no-one does! Ask questions in the forums, fix common issues using our helpful guides, upload your photos to the gallery or buy and sell with the online classifieds.
  • FIAT Forum
    • Forums
    • Gallery
    • Downloads
    • Search
    • RSS RSS
  • Members
    • Log in
    • Register
  • Site Help
    • Contact us
    • Advertising
    • Terms and rules
    • Privacy policy
    • Help
Community platform by XenForo® © 2010-2024 XenForo Ltd.
Proudly hosted with by endrop.
